recirculate door
  1. Amarilu84
    Little Air Coming Out of Vents (Not the Recirc Door Issue) [Solved]
    2008 Dodge RAM 1500 TRX4 Quad Cab, V8 5.7L (Gen 3) Summary: I had this problem, and Google only wanted to talk about the famous recirculate door breaking off and landing on the intake from the blower motor, causing air to stop flowing (or crawl) through all your vents whether it was AC or heat...
  2. S
    HVAC air inlet box
    Hey ram people. My 2018 ram express has lost its recirculating air feature.. I checked the door that the recirculating actuator should move ( which is right above the cabin air filter behind the glove box) and it to no surprise has broken where it connects to the gear of the actuator.. Any...
  3. PE7EY
    Fresh Air Vent Leaking Outside Air w/ Recirculation On
    Hi RamFam, so I always drive using the air conditioner with cabin recirculation ON because I can't stand exhaust fumes entering the cabin, especially when a bus, semi, dump truck, delivery van, etc. is in front of me spewing black diesel exhaust. Recently, I noticed even with recirculation on I...
  4. Dylan_unique
    Recirculation Door Actuator Turning Too Much
    Hi, new here. Seems like a nice forum. Anyways, I had a problem with my AC blower not pushing air through the cab and researched to find that my Recirculate door was broken and blocking the air flow. I removed the actuator so I could slide in the new door and decided to test the actuator while I...
Carbary
