spark plugs
  1. Z
    2012 1500 4.7L V8 Spark Plugs
    Hello all! I'm new here! I got a 2012 RAM 1500 4.7L V8 about a month ago and have made a pledge to do ALL of my own maintenance on it. My dad is helping teach me and also has all the tools you could ever need but he lives a bit far away and can only help when he's in town... I'm looking at...
  2. I
    Four Maintenance Quandaries
    Thank you in advance for your thoughts regarding the four questions at the bottom of this post. I bought my Ram with 5.7 new in March 2014. it hasn’t been used in extreme conditions, is always garaged, and only has 18,000 miles on odometer. But it’s 12 years old. Thought I read...
  3. J
    2017 ram 1500 5.7 HEMI in limp mode
    I have a 2017 Dodge RAM 1500 with the 5.7 hemi. It started misfiring and throwing codes for cylinder 3. I replaced the coil pack and nothing changed. It was throwing codes for the camshaft sensor, I replaced it. Still ran like dog crap. Then it started to act like it wasn't hitting off of any...
  4. MIKEAS97
    96' 5.2L 318 RAM 1500 (Spark plugs)
    Hello, I own a low mileage (81k) 1996 5.2 318 1500, I am getting ready to change my plugs. I see a lot of varying opinions online on what spark plugs to buy, Autolite 3923/3924 come up a lot, stock champions, NGK comes up.. What is the best plug to buy to replace my old ones, my engine is not...
  5. J
    changing spark plugs advice
    i have a 2012 4.7l v8, i am wanting to change my plugs and have bought 8 wires and 8 plugs. I'm reading that some models need 16 total, would this be true for my RAM? just to be clear, its not a hemi. any sort of advice would be much appreciated as i don't want to rip out the plugs prior to...
  6. FORGEDRAM
    Failed Oil Filter Housing / Oil Cooler
    Alright guys, the dreadful day has come. My Oil Filter Housing/Oil Cooler has failed @ 105K miles. Here is a parts list I have whipped up. I plan on doing spark plugs, ignition coils, and valve cover gaskets in addition to upgrading to the Doorman Aluminum Filter housing. Are there any parts...
  7. C
    3.6l cylinder 2 misfire
    Hey everyone, running into a little issue. I have a 2018 Ram 1500 3.6 51,000 miles. Been showing a cylinder 2 misfire, went in and switched plugs, still persistent. I am going to be changing the coil today and see if the issue is still around. My question is really residing, in the fact that, I...
  8. W
    NGK Ruthenium HX vs. NGK Laser Iridium
    Can't find any comparisons between these two plugs, apparently Ruthenium is better for burning a bit more efficiently and also supposedly lasts even longer than the 100,000 plus range. So of anyone has used Ruthenium and compare them to the Laser Iridiums it'd be highly helpful!
  9. H
    Spark Plugs: autozone gave me the wrong ones.
    Hi, got a 2010 ram 1500 with the 5.7 hemi. Swapped the spark plugs and ignition coils about 6 months ago. Been having cylinder 1 misfire the past couple months and the engine has been sputtering really bad with a blinking check engine light. Pulled the cylinder 1 plugs today and noticed...
  10. M
    Spark plug change questions
    FYI - My truck is a 2014 1500 5.7 has 110k miles on it and is running great. Changing plugs in line with the 100k mile maintenance. Not noticing and issues with idle or anything. I am gathering up materials to change my plugs. I have a few lingering questions that I haven't been able to find by...
  11. M
    2014 1500 5.7 spark plug change questions
    FYI - My truck has 110k miles on it and is running great. Changing plugs in line with the 100k mile maintenance. Not noticing and issues with idle or anything. I am gathering up materials to change my plugs. I have a few lingering questions that I haven't been able to find by browsing the...
  12. Numan
    Spark plug part # and gap
    Can anyone tell me the correct spark plugs and gap for my 2003 RAM 2500 with 5.7 hemi
  13. W
    Rough and Inconsistent Idle, frequent stalling and bogging down under acceleration
    I have a 2005 Dodge Ram 1500 Hemi that I have been trying to fix for almost two years now. My brother ran it to empty one too many times and clogged up Injectors and the truck wouldn't start properly again. Had my mechanic take it apart to find the cause and found that a valve had broken off...
  14. T
    Best performance spark plugs and wires
    Best performance spark plugs and wires for Ram 1500 v8 4.7l 2wd has 177,000 miles
  15. NCRaineman
    2012 Spark Plugs... 50,000mi or 100,000mi?
    I've had my truck for about 2 months now and it just hit 52,000mi. I've been reading here and see that some folks are saying plugs are good for 50,000mi and some are saying they're good for 100,000mi. Bought this used and have no idea whether or not the plugs have been changed on it, but do know...
  16. Boosted Motorsports
    Step by Step HEMI Spark Plug Replacement Guide
    I did the long daunting 16 spark plug change on the truck and decided to finally make a good guide for fellow RAM owners to follow to make this job as pleasant as possible. The use of a cheap $12 magnetic swivel socket makes this job 100x better and a moving a few extra things really make the...
  17. RebelRam01
    Spark plug/heat shield removal?
    Anyone have any tips for removing the heat shields to get to my spark plugs in my 5.9 magnum? They are due for replacement and the shields have shrunk from the heat and I can not get the socket down in to remove them. I have pulled one out so far after fighting with it for hours, they do not...
