suspension kit
  1. S
    Lift Ram Single Cab
    Hello yall, I currently own a 2017 Ram 1500 5.7l 2wd single cab short bed that currently sits on a 2/4 drop and 22ich wheels, i had my fun with it being a pavement princess and want to start taking it on some light trails. As I'm looking for some suspension options I realize that there is not a...
  2. OHHPH3
    2012 4x4 Ride height n suspension
    Ok. Ive poured through the related threads and cant seem to land on a good answer. I have a 2012 ram 1500 hemi 5.7L V8 4x4 Doing suspension work. Front strut assemblies need replaced. Ride height is 36in top of wheel well front and back. Id like to maintain this. Does not have a leveling...
  3. 9
    2014 Ram 1500 2WD Express Suspension Replacement
    Hello everyone! All I am wanting to do is replace front end suspension components. All stock truck w/ 20in wheels. Any suggestions on where to look for full kits? Truck is only used as a daily driver. Never goes off road so don't need anything special. Thanks in advance!
  4. A
    Shock Selection
    I have a 2014 ram 1500 with the 5.7. I put methods and Toyo 35” M/T’s I’m looking to get suspension as I want better ride quality (I.e firmer on road less body roll, but still able to cushion well off road. I guess I’m looking for more of a digressive system) I was looking into the Bilstein...
  5. E
    Need Shocks
    did an Inspection at 4Wheel Need All 4 Shocks, theyre all done for. TRACK BAR BUSHING, but want to upgrade to Heavy duty one since this one is Stock. STEERING STABILIZERS TRUCK HAS 7 Inch lift and cant find any shocks with reservoir for front. Any Suggestions?! Called Fabtech and they...
  6. S
    Suspension Upgrade!!
    2014 Ram 1500 Laramie. Just wanted to share with you guys my favorite suspension upgrade I’ve done on my last two rams and about to install on my latest now that I have everything delivered. First, it is not a lift kit. I’ll start with 2” N3 leveling struts and N3 shocks from Rough Country, I...
  7. 9
    Front end rattle over bumps
    Hi there, I have a 2017 ram 1500 with a 2” level kit. I have had a rattle for awhile now and figured it was my cv axles and differential shafts because of the play. I had those replaced and the rattle is still there. I have new struts, upper control arms, and new sway bar links. Anyone have an...
  8. P
    2010 Ram 2500 6.7 suspension improvements
    I just recently installed a the carli 3” commuter 2.0 on my 2010 Dodge ram 2500 4x4 but its still a little stiff. I just wanted to know if anyone has any info on how to make the suspension better without breaking the bank. Any Info is appreciated! Thanks in advance.
  9. OEDRO
    11PC Tie Rod End Track Bar Suspension Kit for 1994-1997 Dodge Ram 1500 2500
    1994-1997 Dodge Ram 1500 2500 4WD 11PC Tie Rod End Track Bar Suspension Kit Use this 10% off coupon code: COUPON10 only cost $125.39. Package includes: - 2x Front Upper Ball Joint - K3134 - 2x Front Lower Ball Joint - K8195 - 1x Front Right Inner Tie Rod End @ Pitman Arm - ES3249 -...
