wheel alignment
  1. O
    Wheel Bearing
    Hello guys, I have an 2009 ram 1500 4x4 with the 5.7 hemi and I recently just got an alignment done and took it for a 2 hour round trip. Noticed I had a consistent steering wheel vibration and slight pull when I drove it over 70 mph. I was familiar with this vibration since I had to deal with it...
  2. J
    22 RAM 5500 front alignment specs
    The outer edges of my 22 Ram 5500 with 60 inch cab to axle distance with 19.5 inch rims and Hankook tires are showing more wear than inside after 7500 miles. Truck has a flat bed on it and is used to carry a 4500 pound truck camper. Front axle weight is about 5500 pounds on CAT scale, well...
  3. RamShark1
    2015 2500HD 4x4 alignment, recall issue, Help
    Hello Everyone- I need some input on my 2015 2500 4x4 currently in the body shop with a front alignment issue probably from a hit and run front left swipe. My right front tire started wearing fast. I though maybe it was just one of my aggressive driving moves and blew it off, unfortunately I...
  4. R
    Strange Problem with check stabilization
    Hi guys, there is a problem. Previously, the stabilization error (top) lit up, but we removed it. I went to the camber, and everything shows perfectly! But.... one day the stabilization caught fire again, and now it is not possible to remove it. We measured the distance of the wheels with a tape...
  5. M
    Needing to adjust Cam Bolt. Lift on Axle, Frame, or Lower Control Arm?
    First time posting and could not find the answer anywhere on the internet. So this must be an easy one for everyone, except me, haha. I have a Stock 2016 RAM 2500 4x4 6.7. Needing to adjust the cam bolt (upper and lower) on the passenger side lower control arm. My question is where do I put the...
