won't start
  1. D
    2016 6.4 cranks but won't start
    I have 2016 power wag 2500 6.4l . Was switched to a side mount battery about a year ago from what I understand. The other night as back out of a driveway my back up cam went out and my wipers turned on very slowly and my power wagon died. Chat the battery and put gas in tank now my power wagon...
  2. cutman2000
    Fuel Injectors-replacement
    My mechanic is gonna check my fuel injectors and says they may need to be replaced. He suggested oem, but that's way out of my budget. My Ram 1500 is not a daily driving truck but a back up. I'm looking at spending $350-$1500 for a set of oem injectors(8). But I'm seeing sets for under...
  3. nevinc
    Issues with 2024 HD 2500 RAM
    I bought a new 2024 RAM 2500 HD and have had to jump start it every day since I got it. Dealer said battery is good and they had no problem. I don't know what to do to get them to understand that every morning I go out to my truck it is dead. I have verified the usual, nothing is left on, I...
  4. W
    Ram 5500 6.7 L full power but not turning over
    As the title says, all the accessories in the truck work, the power is definitely there. When I turn the key the I can hear a click like it is trying to start but no actual turning over. It seems to be some weird connection from the starter, to a little box that is connected to a ground. Has...
  5. J
    Won't Start...
    my 318 first gen won't start... solenoid clicks but that is it. I pulled the starter off and bench tested it and it performed as should, I tried a fresh battery and replaced the starter relay... I also ran a ground from the battery to the starter incase it had a bad ground. Still only get the...
  6. 05ram1500SLT
    Truck won't start when it's -15°F or below
    My truck cranks and cranks but won't start if the temp gets below -15°F. While it is cranking it tries to start but just can't. It seems like the engine fires but just not enough to keep it going. Today was kinda odd because it was -18 out and I was cranking it for a good minute before it...
  7. R
    Low oil pressure but truck oil level is within ok range on dipstick
    I change my oil every 3000 miles and my filter and I run full synthetic Castrol edge high mileage and I probably have done 10 to 12 oil changes this year which is kind of Overkill now my engine has been doing fine all year I have a 2005 Dodge ram 1500 4.7 l Magnum I was driving today and all the...
  8. R
    Truck dies at initial start
    i recently swapped a 5.9l 360 in place of my factory 5.2l I installed a comp cams “RV” cam shaft installed new coil, plugs, wires, distributer cap and rotor, crank position sensor, as well as various other sensors... I got a 5.9l ecu from a local pull apart yard as i had read on other fourms...
  9. TScottinTx1
    Lockdown
    Recently did a engine swap and truck was down for a couple of months. Put everything back together, went to start and nothing. Recognizes the fob, dash comes up, but no radio, can't shift gear, and engine will not turnover. Is this caused the alarm/immobilizer or electrical issue? Any ideas?
giantturkysub
