Help Support Ram Forum by donating:
‘18 2500 Cummins no cooling fan
Discussion in 'Heavy Duty' started by dstryr, Sep 4, 2019.
  1. dstryr
    dstryr The one and only
    117
    90
    Dec 21, 2012
    IA
    Ram Year:
    Engine:
    6.7
    16,000 miles on this thing and twice recently got hot. One 95 degree day and let it idle 4-5 minutes after it was warmed up. Jumped in and temp was iirc around 235 degrees. Got on the highway and a temp warning flashed and then within minutes the temps were back to around 194.
    Most recently 81 degrees and let it idle and temp went to 215, came right back down when I started moving.
    One thing I notice is the a/c always blows warm at idle. Not just a little less cool. No cool.
    I don’t remember ever hearing the cooling fan run. No check engine lights have ever come on.
    Anyone have this issue before?
    Thanks!
  2. thethrillofspeed
    thethrillofspeed Junior Member
    Dec 28, 2015
    Ram Year:
    2014 Ram 2500
    Engine:
    Sounds like a bad fan clutch. I've been through three at 20K miles. I did have the opposite problem, mine stuck on and it sounded like a vacuum cleaner.
    dstryr likes this.
  3. RamCares
    RamCares Senior Member
    2,443
    950
    Jan 21, 2016
    Ram Year:
    n/a
    Engine:
    n/a
    Hi dstryr,
    We certainly understand why this would be concerning. If you decide to address this with your dealer, please let us know via PM. We’d like to have this documented and connect you with a case specialist who will be able to provide an additional layer of assistance during that process.
    Mark
    Ram Social Care Specialist
    Skrap likes this.
  4. SouthTexan
    SouthTexan Senior Member
    1,948
    1,032
    Jan 24, 2015
    Ram Year:
    Engine:
    408 CTD
    I believe the fan is set to come on at around 220F, but I don't believe you have a fan issue. Have you checked your coolant level or if there is any air in the system? The old water pumps tended to leak a little which was why they were recalled last year. If that it s good then I would suspect a bad thermostat or worse case scenario blown head gasket. It is highly unlikely that the head gasket is blown.
  5. dstryr
    117
    90
    Dec 21, 2012
    IA
    Ram Year:
    Engine:
    6.7
    SouthTexan, Yep, everything looks right, fluids are good. I do have a dealership appointment for next week on the steering linkage recall so added this to the ticket. I started the truck yesterday and the fan cycled with the ac on. Strange though that for a good share of the summer- as long as I can recall anyway, the a/c blows warm after a minute or so of idling, at a light, where ever, and it has heated up 2x on warm days. 235 the first time, 215 and climbing the second time. These things should never heat at idle with the size and capacity of the radiators.
    Mark @ Ram Care, I'll let you know. In August 2016 I lost the engine in my '13 1500 due to the lifter problem that plagues the hemi and I'm still not over what it cost me at 112,000 miles.:flame:
  6. SouthTexan
    1,948
    1,032
    Jan 24, 2015
    Ram Year:
    Engine:
    408 CTD
    Hmm, did you make sure there were no air bubbles in the system? I generally squeeze the upper radiator hose on the driver's side of the engine several times to get them out.
    I would also try to take off your grille and clean the radiator the best you can with low pressure water. A friend of mine has to do this on a routine basis because he has to travel down dusty back roads all the time.
  7. RamCares
    2,443
    950
    Jan 21, 2016
    Ram Year:
    n/a
    Engine:
    n/a
    Thank you for the follow up, dstryr. I definitely understand your sentiments expressed here. Please know that our team is always just a PM away if you do move forward with visiting the dealer.
    Mark
  8. dstryr
    117
    90
    Dec 21, 2012
    IA
    Ram Year:
    Engine:
    6.7
    Good call. Yesterday the dealer replaced the fan clutch and for the first time since I bought the truck I can actually hear the fan coming up to speed. 16,000+ miles and it only gets hot when idling. I pulled a car on a flat trailer to Carlisle PA in July and the engine never got over 205 degrees and usually was in the 195-198 range, even in the hills of Ohio and Pennsylvania. Only a 6000lb +/- load so I didn't expect it to get too warm. Just shows that the cooling systems in these trucks have a great capacity to shed heat even without the fan working.
    SouthTexan likes this.
  9. SouthTexan
    1,948
    1,032
    Jan 24, 2015
    Ram Year:
    Engine:
    408 CTD
    That is a little odd since the fan does not generally come on at idle unless you are above 220F and that is when your temps would rise. Mine hardly ever spins at idle and I never have an issue with the high coolant temps.
Share This Page
