01 ram 1500 code P0340
Babyblues36
Magnum V8 5.9
My truck wouldn't start and it has the code 0340. I replaced the crankshaft position sensor and the ignition pickup, and the rotor. It still just cranks but will not start. Can you tell me what to do next ? I've been driving a borrowed car that needs a heater core and it's November. I really want my warn truck back. Thanks.
P.S. I'm a female factory worker, not a mechanic. Lol
Babyblues36
Babyblues36
Magnum V8 5.9
Obviously I'm on my own here.
Villanova
Young lady, try a sensor wiring troubleshoot, also check fuel pump, coil pack. You are correct t on that crank position sensor p0304. ftd
Seadog
Tulsa
Try swaping the ASD relay. Mine does the same. I've changed fuel pump, PCM, cps. No change. Once the relay socket cools it starts. I'm looking for answers myself.
