03 2500 5.7 engine
Gray bead
Mo
I read that the 2500 5.7 hemi had eagle heads is this an eagle block also. And how much extra work is it to put this motor in a 1500
jws123
nj
5.7 hemi engines 2009+ have eagle heads if i remember correctly I think its possible to put eagle heads on a older hemi?.
HemiLonestar
Navy Badge Coast Guard
MD
If I read this the way you wrote it, you read that a 2003 2500 5.7 has eagle heads and block......? LMAO
If that is the case, then no, not even remotely. The eagle was not available until 2009. All 2009+ 5.7's are eagles. No you cannot put one in a 2003 unless you intend to go with a standalone controller or 2005 PCM swap (which requires locking the VVT and swapping out the crank tone wheel) and are willing to totally rearrange your accessory drive.
G
Gray bead
Mo
That’s why I asked if I knew everything I wouldn’t need the forum. Thank you
