05 4X4 Lift...
peeper3011
I recently bought and installed a Supreme suspension 3" Front + 2" Rear Full Lift Kit 4WD..
After cranking the torsion keys and leveled out the truck to match the rear 3" blocks, soon after I had to replace the passenger side wheel bearing and cv axle. I am now hearing a rubbing sound that makes me think the driver side cv is going bad. Anyone had experience with this type of lift?
RMN
When does the sound occur? I put a 5in lift on my '04 ram and it made the similar sound while taking right turns. Come to find out, the angle my cv was at was too severe. causing the cv to bind up. not sure if this helps or not
P
peeper3011
RMN- I appreciate the reply..I actually just ended up replacing everything in my front suspension from cv, hub assembly, ball joints, tie rods, & upper control arms. The noise is gone now and do think it was the cv binding up because of the angle. I ordered the Cardone Select 66-3316 cv axle off amazon and seems like a heavy duty high quality part. Holding up well so far!
