'05 RAM 1500 Stall
VictorBermea
5.9L Common Rail 24V Cummins TD
Is it normal for the motor to shut down after it's been ran hot? My Dodge had died as soon as I pulled in the drive the other day and the temp gauge was about 75% up.
FlaglerMegacab4x4
I would check coolant also replace T-Stat. But yes its possible and not necessarily an issue reason being is your driving slow, and you probably had the steering wheel maxed out so you put a strain on the engine top that to a low engine speed and it loads the motor too much and it shuts down. Having A/C or heat on makes it more prone due to larger draw on the engine. Its happened to me before too.
VictorBermea
VictorBermea
Ahhh gotcha. I was hoping it wasn't anything too serious. Preciate the help Flagler!
FlaglerMegacab4x4
Yea I wouldn't worry about it too much but check the coolant! I had a broken spring on my t-stat and it caused cooling issues so I replaced with a 180 from moes. NP bud that's what were here for.
VictorBermea
VictorBermea
Would it be alright to change the 180 to a 195? Does this make a difference?
Steve58
