yea it does
These are all quotes from "Workin". Apparently its an easy mod on the 06-08 models. The Sport or Laramie cover basically slides right over with no issues.
Quote:
Originally Posted by Workin
If you have an 06 ram, you can slide a sport bumber cover over the stock slt chrome bumber...you will only need remove the upper half. you will need to use a billet grille in the lower opening to hide the curved edges, or just cut it out larger. if you need pics of mine, just holler..........
your right.. this has been covered before.
a sport bumber skin will go over the stock chrome bumber, with ( no modifications ). simply remove the top half of the old bumber.
the only thing that will show is the rounded ends on the smaller grille opening, and if you use a billet insert there, it will never show.
sport bumbers are on ebay all the time.............
yes, and it will fit directly over your exisiting chrome bumber, there is another thread on this somewhere.... you better jump on that price as well........mine was applied over the stock slt bumper
Quote:
Originally Posted by Working
yes... remove the upper assy, remove fog bezels, remove the upper rubber in the center, remove the very outer bumper bolts for reuse...you will have a lower second outer bumper bolt hole in the sport bumper, but you will not need this to hold the sport bumper on......
