08 - crazy winkers
Angelikawahlman
Finland
5.9 Cummins
So my 2008 ram's turns signals blinks too fast. Where I can start looking for the problem?
The light bulbs have been all changed to led but it didn't make any difference when I put there resistor or relay. It also didn't make any difference when I changed all bulbs to the normal ones.
2008 ram 2500 6.7
RoadRamblerNJ
Mountain City, TN
392 Hemi
Do the actual LED's blikn too fast?
I put LED's in my '17 2500, Left blinker has the fast blink INDIDE the truck but both R and L blink normal speed outside.
A
Angelikawahlman
Finland
5.9 Cummins
Yes they are blinking fast outside too. and the odd part is that the first 4-5 blinks are normal speed but then they start fast blinking. and the hazard flasher mode(?) (when the both blinkers are on) is normal speed. so how is that possible? :D
MarshRam
2014 SLT 4x4, 2012 ST
What type of resistors did you use?
SYKRAMMAN
Banned
Jersey shore
06 Mega
Could be multi-function switch. They cause some weird issues, like mine is, on intermittent wiper, it swipes up to 6 times in a row on lowest setting, sometimes it swipes on startup and occasionally won’t turn off. I have read issues where the blinkers work inside but not outside, others have commanded right signal and the left activates and vise versa. It’s something to check out. Part is 70$
A
Angelikawahlman
Finland
5.9 Cummins
Multi-function switch change tried. Didn’t work. Damn I don’t what to do. And I don’t remember what resistors I did use.
So I’m now going to try change all original.
Can you tell me exactly what kind of light bulbs are there original?
Is there anywhere else resistors or something like that what could be broken?
SYKRAMMAN
Banned
Jersey shore
06 Mega
H13/9008
Jeremy slrs
Winder, ga
Same exact problem on my 06 slt with 4.7 resistors dont work. My issue started after adding a led tailgate light bar/strip hazards blink at normal speed thou
