1/4" - 3/8" Wheel Spacer question - where to buy hubcentric and fitment question
ljn21
Does anyone have a link where to buy hub centric 1/4" or 3/8" wheel spacers? I can only find lug centric.
Also, does anyone know how much of a spacer you can use before there isn't enough hub sticking out of the spacer for the wheel to actually grab on to so it centers properly? I want to use the 1/4" or maybe the 3/8" size at the most and wanted to confirm the wheel would still have enough hub to sit on.
L
ljn21
quietpeen
2021 TRX
Hellcat
with any spacer the wheel never sits on the hub anymore. the whole idea of a hub centric spacer is that it gives you a lip that matches your factory hub spec for the wheel to sit on.
here is a link where you can get 3/8" hubcentric spacers. Note: these are not something they have sitting on a shelf. The order goes into be made. it could take more than 2 weeks to get them.
https://www.customwheeloffset.com/c...-4-for-5-lug-and-6-lug-applications-one-piece
L
ljn21
Thank you!!
DavidN
Central Florida
Here ya go: Wheel Adapters, Wheel Spacers, Hub Rings for your car! | Motorsport Tech
I think a lot of people on here use the 10mm spacer.
I recently ordered a set of motor tech custom hub & wheel centric spacers in 9mm for my rear axle.
Was a 3 weeks wait and with $115 shipped not exactly cheap, but fit & finish is well worth it!
Personally I wouldn't go any wider with these spacers as you'll loose too much of the stud thread.
With 9mm you'll have about 7 turns of thread left.
