1 touch up not working
reb0957
Broussard, LA
5.7l
The driver side and passenger both do the 1 touch down thing. Only the passenger side does the 1 touch up. Is it possible it is just a loose connection? Or will I have to replace all those switches in the driver side door?
00R/T
CT
The stops need to be calibrated. Put the window up and down a few times by riding the switch (not clicking to the auto position). When the window stops moving each time, keep holding the switch for around 5 seconds.
R
reb0957
Broussard, LA
5.7l
Thank you very much!
MADDOG
Living in a Firepit
6.4L HEMI
Here is the calibration sequence:
With the window fully up, press down on the button and hold until the window is fully seated, count One Two & release button.
Now, pull up on the button and hold until the window is fully seated, count One Two and release button.
Do 3 or 4 full sequences of UP Hold release Down Hold release
