1000$ budget...
mopower
magnum 5.2
i got 1 grand to spend and i wanna put it into my truck... i wanna put some mods into my engine that will give me the most bang for my buck...any ideas?
quietpeen
2021 TRX
Hellcat
Whay kind of bad luck did your buddies have with programmers?
nim81
Fredericktown, MO
5.7L
I have a bully dog gt and it's frakkin awesome. Has all the engine parameters at your finger tips and has a mean performance tune
- Sent from iPhone-taptalk
RubberFrog
The OP has a 2000 5.2, so serious tuner performance is not going to be there. Look into a set of gears.
txbass06
NE Texas
5.9 Magnum
I'm with George. Tuning for the 2nd gen gassers isn't good for much. Gears would give you the best bang for the buck unless you had a hookup at a speed shop and wanted to do some serious engine work
- Sent from my iPhone 4 using Tapatalk
nim81
Fredericktown, MO
5.7L
On my iPhone didn't see any vehicle info...
And I completely agree with gears!
M
mopower
magnum 5.2
Well some of the programmerS must have leaned out there trucks or something and blew em up. Anyone got a programmer they wanna sell?
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
Headers and one of those Jet Stage One Chips that piggyback onto the PCM. had one on my 89 5.0 and it was awesome but then again I had a distributor and also bumped the timing up.
Agree with Gears but would 1K do it (2wd I Guess so).
M
mopower
magnum 5.2
Ya i deffinantly need 4wd so gears is out of the question... If i wanna do that jet chip do i need to buy the stage one if i wanna jump to stage two
M
mopower
magnum 5.2
Would throttle body spacers do anything or is there any fuel mods like high flow throttle body injectors or some **** like that
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Throttle body spacers do nothing for our 2nd gens. There is no air fuel mixture done in the intake. All that is done in the cylinder. So those are just big expensive paperweights. And from what I understand those Jet chips are almost a joke. All they do is fool some sensors no real performance there. Depending on what you are wanting to do would depend on where to go. If you want go fast mods then look into an intake and some RR's
If you just want some more function then I agree with some gears and a plenum fix. Plenum is a very common problem and if addressed correctly can add some more power. But the basics is a tuner, CAI (cold air intake), and maybe gears. There's lots of options just depends on what directions you would like to go with the truck.
Welcome to the Forum too!
M
mopower
magnum 5.2
RR's? But im looking for more power really to get going faster add some hp and torque. So now what would you suggest
M
mopower
magnum 5.2
And whats a plenum fix...?
pavester
texas
GEARS will get the heavy truck moving, intake will get it breathing better, headers will open the exhaust up, new exhaust will smooth the airflow and not hamper it.
JET CHIPS ARE THE BIGGEST RIPOFF.
TB SPACERS DO NOTHING BESIDES MAKE NOISE
txbass06
NE Texas
5.9 Magnum
On the V6 and V8 Magnum engines, there is a steel plenum plate on the bottom side of the intake. As we all know, steel and aluminum expand and contract at different speeds and eventually causes the plenum gasket to fail. There's two ways to fix it.
Just replace the gasket and wait for it to fail again or get with a company like Hughes Performance and order their plenum kit. It'll come with new gaskets and hardware and a new aluminum plenum plate, that way you'll never have to worry about it failing again.
M
mopower
magnum 5.2
Well i was thinking shave the kegger and i have an in on an emgine shop i was thinking valve springs
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I have a DIY on shaving the kegger here in the DIY section.
RR is roller rockers.
Also could get bigger throttle body, I think around a 52mm, stock is 48mm if I am not mistaken.
I agree with what Kyle said above too
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
You can still do gears being a 4x4 just gonna cost a few. You will be close to the $1k mark.
