$12.45 addition
JohnnyDollar
Texas Hill Country
I don't know if this is considered a mod, however,
I have a upper glovebox which has a cutout for a light. I noticed that the wiring harness is there, plugged into a blank filler piece.
I ordered a light switch on e-Bay: MOPAR OEM 4565022 Glove Box Lamp for $12.45 delivered.
Popped it in and it lights right up.
Wiring harness plugged into the blank:
Plugged in and snapped back into place:
Cheapest thing I have done to my truck since I bought it.
WhiteExpress
Midland, TX
I kinda like not having the upper glove box.
But having it lit would be much nicer!
Alfonsio
2010 Big Horn Quad Cab 4x4
That's good to know! Thanks for sharing!!
RamHemi5.7
Gilroy Ca
2013 Quad Cab
Hemi 5.7 8 Speed
Ha! Very cool! i was wondering why my upper glove box didn't have a light. I'ma do the same thing! Thanks :)
JohnnyDollar
JohnnyDollar
Texas Hill Country
Something as simple as this should just be standard with the upper glovebox.
I mean, the hole is there, the mount is there, the wires are there and it's not an expensive part
I guess I need to look and see if the underhood wiring is there,
Because I don't have a light there, either.
Diller
Nashville TN
6.7 HO Cummins
I can't believe that they found it to be more cost effective to run two different pieces than just put a light in every one. It is massively expensive to run separate parts (I work at a tier 1 supplier).
The only thing I can think of is that the cost actually balanced out and that is one "feature" to try to sell the higher end trim packages.
JohnD72
Charleston, SC
Are you able to help an old guy out with a part number for an LED replacement bulb?
It looks like you have a 194 bulb there. The Sylvania LED replacement is 168-194LED.
Autozone seems to have them for $10.
JohnnyDollar
JohnnyDollar
Texas Hill Country
Thanks guys.
I will try Autozone.
Any luck finding the others local?
Cruizer
Ohio
2010 Sport 4x4 QC
Now I gotta go look at mine and see if I even have a light. Nice find!
Alfonsio
Same here. I assumed I didn't have one but its there.
Thaylin
Ottawa, Canada
What do people typically put in the upper glove box if it doesn't have the door? It's more like a cubby hole.
Compiled by an Android
hunter99
It's no different than the under hood light plug being there and simply needing to buy the harness and light. Also the same with trucks that didn't have the USB in the rear of the glovebox and finding it is ******* in the harness unused. I really don't get stuff like that at all.
moledodge
DAT HEMIIIIIII 5.7
Man these guys cut costs everywhere
Jtucker21990
