13+ ram 1500 full size spare possible?
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Does anyone know off hand if a 13+ 1500 factory Sport Wheel & tire will fit in the spare tire spot? (ie full size spare w/20" GY SRA's).
M² Mods - From my non Flammable S7!
stimpy433
IOWA
I've seen posted in a couple of other threads that a 20" Chrome Clad with the stock size tire will just barely fit.
R.L.K.
Bristol , Tn.
I'd say yes , as the spare tire location is only limited to the OD of the tire , if it's of stock size then certinly It should fit .
Sent from my SM-G900V using Tapatalk
AFMoulton
Nuevo Mexico
My truck has a full size spare.
DwnDak
Ontario, Canada
I can't say for sure on my 16 but all my other Rams have had full size spares.. Wheel itself won't fit... it'll just look like poop after a while depending on where you live, thats why they come from the factory with steel wheels.. also its a cost savings for them.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
My spare tire is the same tire as the rest of the tires on the truck, if it was on the same wheel you could easily take it out and us it in the tire rotations.
DavidN
Central Florida
It will fit fine. One issue though - The bracket on the end of the winch cable will not fit through the center bore of an alloy wheel.
You could modify it though. Slot it with an angle grinder so you can remove it from the cable, feed the cable through the wheel and attach the bracket then.
The bracket will scratch up your alloy wheel pretty good though.
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
I thought full size spare was standard equipment? my 2014 express 1500 and my 15 2500 big horn both came with full size spares.
