1500 120v dash outlet module... internals?
Kraken
So it's still way too ****** cold to be doing stuff like this outside but I wanted to ask if anyone had taken the outlet module apart? I've noticed the inverter does not power up.. or at least the indicator light does not illuminate unless a power cord is plugged in. I'm interested to know what drives this? Physical microswitches? Some electrical load sensing?
Anyone know?
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
If @00R/T is still around he will know and has had it apart.
  • 2015 Ram 1500 POWER-OUTLETS.pdf
Anyone know?
I'm no electrican,but it looks like it needs something plugged in to actually complete the circuit to the light.It looks like the invertor is powered,but the light isn't activated till you plug something in
Kraken
Kraken
Yup thats the diagram I found a bit ago... providing one did not exceed the wiring ratings, and the fuse, any relays as well. One might be able to upgrade that factory inverter a bit. NOTE I did not say swap it with one rated for a few thousand watts. I merely mean.. maybe it's possible with a bit of diy, to replace it with say 400w.
IDK.. spitballing out loud.
RamDiver
Marlborough, Ontario Canada
2021 DS
Please tell me how you calculated the existing build could handle a 400 W inverter. :cool:
Kraken
Kraken
I didn't. I did elude to a possibility of upgrading.. the 400 number was straight out of my anus.
alphaprojects
