Fast69Mopar
Yes, most of the aftermarket fuel pumps are too small in diameter for the stock housing. There is quite a large difference between the plastic hole in the housing and the new pumps.Is it the container that holds the stock fuel pump the hang up I take it? I should have paid more attention when I dropped the tank to fix my fuel level sender. Just realized the replacement lasted longer than the original.
So the plastic holding the stock pump needs to be modified to hold the aftermarket pump? Check. I should order a stock replacement pump setup and an aftermarket pump. See what I can come up with. I wish I had more need around fuel system.
