Fast69Mopar
I set it up just like it came off of the assembly line by installing the C7 pump into the Mopar fuel pump module. I wanted it to utilize the factory fuel pressure regulator in the housing for this 2009 RAM because I didn't have time to set up a return style system with an external fuel pressure regulator in the truck.Great info and thank you. I will take my 19+ C7Z/ZR1 pump that’s actually supposed to flow even more and put it in my Ram then. Did you connect the check valve and lines like factory? I have a BAP on my C7Z and also a auxiliary fuel system. On 19psi and E60 the low side doesn’t budge. This is a 2650 blower heads cam high compression setup that is somewhere around 950-1000whp.
The C7 pump actually works quite well in the housing and provides plenty of fuel for the N/A setup
