18 Ram 1500 front calipers replaced. Brake fluid bleed question.
El Gallo
North NJ
3.6L Pentastar
Hey guys, as stated in the title I replaced front calipers on my truck. Do I need to bleed all 4 out now or should I just be able to bleed those two and be done with it? Does ABS module also require bleeding? Thanks in advance.
El Gallo
El Gallo
North NJ
3.6L Pentastar
I ended up bleeding all 4 and bled abs using Alfa. I then realized that my calipers were installed backwards . (Bleeds on top do make a difference!!!) I switched them and then just bled the front and that was sufficient. Very very quick bleed; one pump per side was basically all the air that it had. Hope this helps others.
