BurtShaver
The hose 68204418AC is leaking between the master and the HCU, can I bleed the brakes as usual after changing this line?
Back story, I was backing some trailer up on my front lawn this winter and the brake peddle went to the floor while doing it, couldn’t see any leaks, master cylinder reservoir didn’t appear to have went down so I thought it was the master cylinder. I still had brakes at the last inch of travel but the peddle went all the way down without applying any pressure at all.
Left it, as I was going to wait till snowmobile season was over to fix it. Then I wanted to use the truck to go get a snowmobile lol, and when I was moving it, I could see a fair amount of fluid on the ground leaking out from around the front left wheel, after looking I found it was the line from the master to HCU.
After noticing the leak, th master reservoir was about half full, I filled it back up, it’s never been below half full.
Ny plan to change the line was to remove the end from the master first and use a rubber cone that comes with my mity vac set to plug the hole in the master, take the other end of old line off of HCU, then put the end that goes to master in first so that fluid will fill the new line and then connect other end of new line to HCU.
My big question is will I be ok with bleeding the brake system at each wheel or will I need to pay someone to bleed it with a special tool?
What order would I bleed this system? Furthest from master first? Then other back wheel l, then right front wheel and left from last?
