One mod the owners wanted to make was a simple one. Aluminum valve covers were sent to me from the father in law of the person who will be driving this truck as a surprise. The owners initials are MT and so is the script on the valve covers. It was a thoughtful gesture and meant to be a surprise, so I kept these pics to myself until given the all-clear.
Steel valve covers are the one glaring black mark on the US domestic automotive industry. One word describes them. Leaky. Even with good gaskets, they need constant attention to keep the oil on the inside. Aluminum, on the other hand, is nice and rigid, and will hold the gaskets torqued more evenly. I did want to make a couple changes first to make them fit like the original steel covers. I machined a quick block of aluminum to mount the vacuum solenoids on the passenger side cover, which I then TIG welded in place. Then on the driver side cover, I cut a hole for the PVC, to relocate it to the back of the cover, where the original valve was located.
The grommets were solid without tears, but hard as rocks. Here's a quick tip that I hope you all pay attention to. When you have old rubber that's hard as a rock, let it soak overnight in a mixture of equal parts acetone and ATF. The acetone helps open the pores to allow the ATF to penetrate the rubber. The results are unbelievable. I literally didn't believe it the first time I tried it, but it does work.
With a new coat of Porsche silver and soft rubber grommets installed, so went the covers. I think it looks nice. And I hope the owner does too.
