1999 2500 brake pull
2serious
long island
Hey I have a problem with a 1999 2500 disc in front drum rear. Rear abs only. Here's what I've done. New calipers. Pads. Hub bearings. Lines from master to calipers. Steering components. Rotors. Tires. And bleed em about four times. The rear has also new cylinders drums and pads. Any ideas?
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
I'm guessing that it is pulling to one side over the other? Or maybe it feels like the brakes are on all the time?
txbass06
NE Texas
5.9 Magnum
We might be able to help if we know what's going on lol
2serious
2serious
long island
Sorry lol yes pulling to the right when stepping on the brakes
txbass06
NE Texas
5.9 Magnum
When it pulls, do you feel it in the steering wheel?
And what order did you bleed the brakes?
2serious
2serious
long island
Yes whole truck makes right turn. And yes pulls the steering wheel. You can hold it and fight it. Left side brake works also. Seems like the right is just stronger
2serious
2serious
long island
Sorry the order was farthest to closest. Never had a problem before with brakes pulling was only as simple as a caliper a hose or air. I'm a mechanic by trade so not my first rodeo. Just super stumped here.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Something to check is the possablity of the left side not apply enough? did you double check the sliders when you put the new calipers on? Also witht he new caliper did you double check how the line connected tot he caliper. Sometimes the little hole in the bolt doesn't line up giving the illusion one is pulling harder than the other.
Just a couple thoughts.
Edit: Well we posted at the same time. But sometimes its the stupid simple things.
2serious
2serious
long island
Yes all sliders clean free sliding awesome. I ordered another set of calipers just for the hell of it. Never know get a defective one or something. Start there and I'll report back tommorow. Thanks for the tips
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
No problem glad to help. You know as well as all of us you do get faulty parts at times that cause super headache. Good luck! Let us know what you find out.
2serious
2serious
long island
Well chalk another one up to those great reman parts. Two new calipers and she's good.
