sentrek
Could use some input.
Finally got my sons 99 1500 back up and running after a new engine install and was having some brake issues, actually the brake issues started before we replaced the motor, but anyway, I replaced the pads, rotors, calipers and master cylinder, and the wheel speed sensor. I bench bleed the master cylinder before install per the instructions and i though were were good, pedal was solid, abs light went out, but as soon as went to pull out of the garage for a test spin the pedal went back to the floor. Any idea what to look at next? I could not find evidence of a leaking line or anything anywhere. I bleed the brakes after installing everything as well. Kinda at a loss.
