1st Post (Lifetime Powertrain Warranty)
bphays
Enterprise, AL
When I returned from Afghanistan in December 2008, I purchased a new 2009 Ram Laramie 1500. AWESOME truck!! With the truck I purchased an extended warranty that took me out to 75,000 miles.
In October of 2012 (55789 miles) I started noticing a tapping noise come from the engine that sounded very expensive. I took it to the dealer and was pleasantly surprised when they told me that I had a lifetime powertrain warranty, and hoped that it was covered. After a week they determined that (quoting from the service order) "the roller bearing on cylinder #7 exhaust lifter disintegrated causing the cam shaft and lifters to fail and causing tapping/knocking heard at idle...found almost all cam lobes pitted and second to last cam bearing has unusual wear".
They "installed new camshaft and lifters...new oil pan gasket, reinstalled both cylinder heads, front timing cover, crankshaft rod bearings and main bearings, oil pan, fresh oil and coolant, started engine and monitored idle quality". The knocking was gone and I walked away with a "rebuilt" engine very happy. After a rental for 3 days and all repairs, my charge was $0.00. :)
Fast forward to July 2014 (74989 miles). We were heading out of town, the extended warranty was almost up, and another knocking sound was discovered at idle until warm. So, as I wouldn't need the truck for the week, I took it in again. Again, quoting from the service order..."Checked and found broken bolt in right side exhaust manifold, removed manifold to get broken bolt out and replaced gasket and all bolts". $1087 worth of work performed and I only paid $202 (oil change, tire rotation, new key fob-the old one just quit working, extended warranty deductible).
I asked the service lady how a "broken bolt" ended up in the manifold and she said she sees them often. Guys...if you've got a tapping, take it in and get it checked out. Those of you with the 2009 Dodge Ram, you have a LIFETIME powertrain warranty as long as you're the original owner. I will drive this thing for the next 40 years and end up giving it to my grandchildren.
bigbadram1500
Springfield, IL
That's awesome. I also have the liftetime powertrain on my 2008. I had the first check done at the end of 2012 after 5 years since purchase. I now have that ticking/knocking until it warms up. I need to get it in, as I'm pretty sure it's a manifold bolt too.
THETANK
up jor *** mang
2015 R/T
Yikes. My 14 does not have the lifetime but I did purchase the 7 year warranty. I just have to keep this truck more than the 2 years I keep a normal vehicle lol
BlownGP
Houston/Baton Rouge
The broken bolts on the exhaust manifold is a common thing on the 2009 to 2010's.
Yup..
Mines been ok so far, but I do have issues. Long Tube time.. haaha
Wish I could have bought mine new...Then again probably wouldnt be able to mod it as much..lol
Ramzaq
Northern California
2009 CC 4X4 3.55 Big Horn
That is the great thing about 2009's, lifetime warranty. One of the biggest reasons I bought mine.
You must have the vehicle inspected by Chrysler every 5 years to keep it in effect, if you don't, it will be void.
mtofell
I bought the Lifetime Maxcare (basically bumper to bumper warranty) on my 2014 6.4 Hemi 2500 for about $2200. I hope it pays off someday. If nothing else it's a great feeling to not care at all what a given noise is. As long as it doesn't leave me stranded on the highway I don't really care what goes wrong :)
