2” and 2-5/16 180° slider for 2” shank WeighSafe hitch
Status
Not open for further replies.
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
Being that I upgraded my hitch to the slider with the scale built into it, I’m selling the 180° flip slider that came in it since my needs have changed. This slider should work on any length of any WeighSafe drop hitch drawbar that has a 2” shank for a 2” receiver. Has the 2” and 2-5/16th hitch balls. 2” is rated 8,000 pounds and the 2-5/16 is rated to the full capacity of the hitch which is 12,500 pounds. The 2-5/16 ball does have a slight scratch on it from dragging the ball when it was all the way down in the full 6” drop but it’s not bad. The hitch has been lightly used only to pull a little 10 foot, single axle utility trailer with no more than just a riding lawnmower on it. Hadn’t been used to pull anything real heavy.
Based on what the slider and the double-ended ball cost when new, I’m asking $120 shipped to anywhere in the US. Thanks. 3cb4dcf3c15c05fb318b10a00f61bb67.jpg
corneileous
corneileous
Podunkyville, OK
Oh, and just for extended information, if you happen to have the 2.5 inch shank or even the 3 inch shank hitch, I’m pretty sure this combo ball will still work for that even though it only has the max trailer weight of 12,500 pounds stamped on the 2-5/16 ball because if I had to guess, they’re all the same ball but if you get the hitch combo that comes with the 2.5 inch shank, the bigger ball will have 18,000 pounds stamped on it and the bigger ball on the 3 inch shank will have 21,000 pounds stamped on it.
corneileous
corneileous
Podunkyville, OK
Bumpity bump....
corneileous
corneileous
Podunkyville, OK
Price reduction down to 95 shipped.
Status
TMFMK
