2” puck lift
Dmehrl
Iowa
5.7 etorque
Want to add 2” lift to front of 2021 ram 1500 Laramie. I’m looking at the 2” spacer puck type. Anyone have this done, and happy with results ? Any pics ? Thanks in advance !
crazykid1994
You would be better off with a set of leveling struts. They help keep the front suspension geometry within factory specs. Top spacers can allow the suspension to overextend and can be bad for ball joints and cv shafts if you’re 4wd because it pushes the whole assembly down out of factory specs. If you use a preload spacer on the stock you would be better off than a top spacer because it’s not pushing the whole strut assembly down. if you need help finding something or would like a quote on parts @Nick@GotExhaust is awesome and very helpful.
Nick@GotExhaust
Supporting Vendor
SC
I agree with all said above. If you want a lower cost leveling option then the minimum I recommend is the Bilstein 5100. We have better options but the 5100 is the cheapest option of leveling a RAM the correct way.
message me if you would like more info or a quote
Ghstrdr95
