2.1 or 2.8!!???
Fletch125
2014 Ram 1500
3.6L
Cannot settle on a choice for my bils. Ground to center of wheel well is 37.75" up front and 40" in the rear. Which means I have 2.25" of rake. Id hate for the front to be too high and have to add spacers in the rear 59221313b45f212ceccbf52c79284e33.jpg
dmalonecentral
Tempe, AZ
5.7L HEMI® V8
I was at 36.75 in front and 39.25 in back. I went with the 2.8 and it came out nearly dead level. Not sure why I didn’t get all 2.8. But I went in with the mindset that if it wasn’t level I would add the spacers. If you absolutely don’t want the spacers I would go 2.1.
Reactions: JB1
Seth_5.7
North Carolina
I had similar measurements as you and I set mine at 2.8. It was nose high for about 3 days then it was dead level after settling in.
Whiteannerdy
Very similar measurements on mine before I did them last week. Went 2.8 and I wanted rear spacers so I put readylift 1.5s in as I don’t mind the rake. Sometimes I have a little Weight in the rear but rarely tow anything.
After mine installed I got this look. Did the alignment 3 days after install and I have had zero death wobble in 4x4 Lock at high speeds. Smooth as before. If I went 2.1 I would have been disappointed because the 2.8 just barely clears my 34s. Not enough to fit 35s without rubbing again.
Frosty415
Wisconsin
I'd say if you're totally against spacers do 2.1. I don't remember my measurments but I did 2.1 and still added spacers because I ended up with just under 1/2" of rake and didn't like the "saggy" back end.
Fletch125
Fletch125
2014 Ram 1500
3.6L
Before and after. Went with 2.1 and it was perfect. Less than 1/2" of rake. 071af133003006e9b0c073cdda9dd654.jpg
barbosa
Struggling with this same decision, but I am towing a trailer weighing at least 3k (often 5k+) 3 or 4 days a week for work. I don't really want to add a spacer in the rear, but will probably need to put air bags in the rear springs to help.
I've had the Bilsteins sitting in my the garage for over 3 months now :sleepy:
dhambyst121
I have the 2014 Ram 1500 Outdoorsman Crew Cab. I want a 6 inch lift with Bilsteins all around and am considerring the 6 inch Superlift with the bilsteins ir the BDS 6 inch with Fox 2.0's.
The problem I have is the 2014 Outdoorsman already comes 1 inch higher than the stock 1500 SLT so they warn against the 6 inch lift due to cv vibration and alignment issues.
Anyone out there with the Outdoorsman that can point me the way? I want max lift with no more than 1 inch of rake. Perfectly level is not a priority for me as I will occasionally pull a trailer with a riding mower.
I have heard as long as I don't go 2.8 on the bilsteins I will be ok. Is 2.1 ok or 1.4? I don't want to wear out the cv or other components or fight alignment issues.
I'm putting 35x12.5 Mickey Thompsons on a set of 20x10 wheels as well.
Any help is appreciated.
Sent from my LG-LS997 using Tapatalk
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
You will never have the death wobble with a IFS truck only a sraight axle truck.
dhambyst121
So much misconception out there about the "Death Wobble".
Post of the day [emoji115]
Whiteannerdy
Was pretty sure I read lots that these 4th Gen 1500s are hit or miss that it happens.
Regardless I’m still happy I haven’t had this issue. Though I rarely run higher speeds in 4x4. Usually run 4-Auto all winter and 2-Wheel in summer. Then 4-lock in deeper snow/lower speeds and have yet to make any use of 4-low.
dhambyst121
IFS = Never having to worry about the "Death Wobble"
