2/4 Belltech: Height Measurements?
MarshRam
2014 SLT 4x4, 2012 ST
Curious if anyone has this on a single cab and what your measurements are. This was installed already when I purchased the truck. My rear sits an inch lower.
Measured from ground to fender at center caps, I am sitting:
34.5" rear
35.5" front
Kevin Barker
Greenwood SC
I have the CC, but my rear is almost 1" lower than the front as well. I do apologize for answering knowing I cannot answer the "single cab" part.
dracman
canada
2011 ram 1500 reg cab.dads ol truck
bell tech makes a one " spacer been there done that .mine was lower in rear to
dracman
canada
Here’s some pics
gbark80
Georgia
I posted this on another post last week, but looking at your measurements, you probably have 1 coil cut off in the rear.
So I measured around the coil and cut 7 1/2 inches measuring around the outside of the coul up front and 1 coil rear, plan on cutting 1 more off this weekend in the rear. I measured ground to wheel well opening with tape measure centered in the center cap.
STOCK.
LF-36 1/4
RF-36 5/8
LR-38 5/8
RR-38 7/8
CUT COILS
LF-32 3/4
RF-33
LR-34 1/4
RR- 34 1/2
HEIGHT DIFFERENCE
LF-3 1/2
RF-3 5/8
LR- 4 3/8
RR-4 3/8
If I hadn't dropped to a 275/55- 20 tire, the height will be a half inch taller as that tire size is 1 inch shorter over all. With stock tires, the difference with what I'm running would be.
LF-3
RF-3 1/8
LR- 3 7/8
RR- 3 7/8
Height should be
LF 33 1/4
RF- 33 1/2
LR- 34 3/4
RR- 35
Would like to know what you measure at if you can post it.
I also had about 1/2 a tank of gas as well. Hope that helps.
I cut another coil on the rear over the weekend, gonna get measurements when I get about the same amount of gas and the coils settle back in.
gbark80
Georgia
I like the stance, are you running relocation brackets or no?
Not yet. I ran it up to about 95 on I20 the other night and no wobble so that is good. I did bottom out on a harsh speed bump since, so different bump stops are definitely on the agenda for this weekend, and IHC brackets later in the spring or early summer are in the plans, if I keep it, lol.
