At 1000 miles on my 2014 1500 I put on the hbs 2" pucks. It rode fine for about 500 miles then I started feeling a loose busy feeling in the front end, but I didn't think much of it. As sometime went on and the miles piled up (3000 to be exact). The busy feeling got unbearable. I came here and found out about he bj issue and promptly ordered zone uca's. The install went great just under 2 hours (no sweat) I got the alighnment checked (stupid ntb) noticed my camber was 5 degrees but couldn't get them to work on it. ( time constraint). Now the busy feeling is back. Not even 200 miles on the zones. I can feel every single bump through thesteering wheel.
Anyhow could riding around on those bad upper ball joints for about 2500 miles have messed up the lower ball joints? Could the the excessive camber give a lot more road feel? Everything seems tight. No weird noises or thumps just a lot more feeling in the wheel. ( not the nice numb feeling when I first got it). Btw I'm running factory air pressure in thestock wheels and rims.
Casey j.
Casey j.
