2 ohm amp question
2010 Infantry Vet
Butler pennsylvania
My kicker KX650.4 amp settings:
120 RMS x4 @ 4 ohms
170 RMS x4 @ 2 ohms
My components are 100 RMS and i want to know if i can run infinity kappa perfect 300m 3.5" midrange speakers (some places say 70 RMS, others say 35 per speaker) on the same channel, and get the most out of them.
The Infinitys are 3.5 ohms.
By running at 2 ohm all the time, am I running a high risk of burning up the amp? Or should I get a seperate amp for the 3.5 mids?
adrianp89
Tampa Bay, FL
The amp is 2 ohms stable, so it will be fine. It will probably sound like crap adding those with your components though.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
They'll be bright, unless you want 8 ohm 3.5, but with components already, meh...don't need the 3.5" IMHO
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
Unfortunately only 2 companies make designated 3.5" midrange speakers. JL audio and the Infinity. From the reports i read, the Infinity midrange speakers sound better than the JL. We dont have many options. I might try to amplify the JL 350x coaxials with the components and see how it turns out.
Right now i have the JVC headunit running the JL audio 3.5" coaxials, and the kicker amp running the components. Gain was adjusted so i didnt have to add resistors and worry about burning my truck down. Sound is nice and even now.
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
These arent coaxials. They are designated midrange speakers like the JL audio kit uses, but 75RMS.
The JL midranges wont fit our dash, they are 4".
autokraftgt
Hemi 6.1
Gonna have to disagree ... there are many many options for a midrange in the dash of a Ram...ya just have to get away from the popular brands and go with raw drivers (that will sound better and cost less more than likely). I ran a 4" Scan Speak 10F in my dash and was able to use the factory mounting holes...just a minute of trimming with my Dremel to clearance the magnet and I was good to go. When I traded my truck in, I put the factory speakers back in and no one knew I had been in there. IMO, If you want to run a dedicated midrange, you've technically entered the 3-way world and I would highly recommend getting something that will control your front stage crossover points for MIDbass, midrange, and tweeters. With midrange running off HU power, you technically have two sets of speakers playing many of the same frequencies (tweets & midrange) so you have some interference going on. You may think it sounds great now...but if your get your crossover points under control...you'll be amazed....that midrange has propelled you down the rabbit hole....congrats!!!
adrianp89
Tampa Bay, FL
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
Thanks I was not aware of that brand. I will check them out.
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
I am aware of what they are. But unless you have a way to cross over all three speaker correctly, this will sound bad. At least it will be loud though.
Autocraft hit it on the money.
damn...never even thought of the crossover (hits hand on forehead) lol. Guess i will stick with the 3.5" JL coaxials.
TomT
SoCal/OC
Are you running any kind of DSP in your system? Also, your amp may have crossovers built in that you can use to band pass the signal for midranges.
I have 4” midranges in my dash (Dynaudio e430s) and I don’t believe the installer had much of an issue making them fit.
I ran across these recently and they get good reviews from the Car Audio fanatics on SSQ and Diyma. These are 2.5” mids, they also make a 4” version.
https://www.audiofrog.com/gb25-2-12-63-mm-audiophile-grade-automotive-loudspeaker/
TomT
autokraftgt
Hemi 6.1
TomT
I ran the e430's in my dash as well. Pretty easy install. I needed a new kidney so I sold those which covered the entire cost...jk
Something tells me the dynaudio and Audio Frogs are bit more than the OP wants to spend....considering the guy may have to buy a dsp etc to quarterback his front stage
TomT
SoCal/OC
True, I went overboard on my latest system (thank god for SQ nuts who swap gear often so I could afford some of it). If I was starting from scratch right now I would probably go with Audiofrog GB series.
autokraftgt
Hemi 6.1
Im still a Dynaudio guy. Love the AF stuff...its great stuff. But nothing matches the realism that dynaudio provides IMO
Graygoose
Oklahoma
Convert, for now.
small
Am great friends with one of the guys that started Audio Frog, Gary Biggs, some good stuff...pricey though.
TomT
SoCal/OC
Hertz also makes 3.5" drivers. I have a set.
I still have my previous Hertz system (Hi-Energy 3 ways front and 6.5 coax rear) sitting on a shelf waiting for me to list it somewhere. Ran them biamped using Focal passive crossovers and a Bit One.
I should probably stop procrastinating and get them up for sale. LOL
electricalservice
