"2 or "2.5 front level on 2wd
jei3us
5.7l hemi
Looking to level my 2wd in the front I've measured about 2.5 inches shorter in front to rear difference. The kits I'm looking at come with the spacers and longer pro comp shocks. I want the truck to be leveled I wouldn't mind a little higher squat up front so long as it's not too big of a squat. Should I go 2 or 2.5? My concern is I don't want to go with the 2 and find out it still sits lower up front.
EWC88
Southern NJ
I'd say if your fine with front being higher if it happens then go with 2.5", but I don't have a level kit so I'll let others chime in.
xtremewlr
Tucson, AZ
I'm in the same boat with my 04. I measure 35" from the ground the the fender lip on the front and 37.5" at the rear. I can't lower the rear so I am thinking about raising the front a little to level it out. I was thinking 1" or 2" spacers but I want to know if they truly give that amount of lift or is it more or less? Maybe it would be better to go with lift coils?
derekp
Buda, Tx
1990 5.9 Cummins
Took me 2.5" spacers to get it level. Now its right on the money. Make sure you have a good set of coil clamps when you do it. It will make your life so much easier I promise. lol
