2 question about my 2011
02blkram47
Lebanon, NH
2018 Ram 1500 Limited
I don't have an owners manual so I can't find this info. Hopefully someone familiar with the 2011 Laramie Longhorn can come in.
1. Does this truck have a trip gauge? I can't find any way to track my millage after a fuel up. Usually a truck or car had a meter you reset..
2. On my key fob, I notice often that If I just brush my finger across the buttons my lights with flash. As far as I can tell it doesn't lock or unlock but it flashes the lights...what's the purpose of this?
Thanks for any help
Sent from my XT1635-01 using Tapatalk
I can't say much for the first question. My 2013 ram 1500 has the trip meter somewhere in the options on the instrument panel.
My key fob does the same thing yours does. Mine will actually lock the truck just by me touching the lock button. I've opened the key fob up before and moved the small rubber contact pad back into the correct place but it always moves back. Figure I can get some super glue on it to hold it in place [emoji1303]
Ohio
Thanks for any help
Does your steering wheel have a button labeled step? That should cycle through odo. Trip a and b, exterior temp and such. You can reset it there somehow i believe
02blkram47
02blkram47
Lebanon, NH
No it doesn't..Just the select, back and two arrows
02blkram47
02blkram47
Lebanon, NH
I'll have stand close by ava try it to see if it locks or unlocks
chris52010trx4
ontario
on your guage cluster it should have the stick thingy push it it will go trip a and then again will go b ... to reset hold it in till it goes to 0
02blkram47
02blkram47
Lebanon, NH
You know, I've seen that stick and when I push it it does nothing. It doesn't cycle through anything. Must be busted, when I try to push it it doesn't travel really at all.
chris52010trx4
ontario
Does it turn... I know mine pushes in but other vehicles sometimes turn? It probably doesn't but it's worth a try...
Sent from my SM-N910W8 using Tapatalk
02blkram47
02blkram47
Lebanon, NH
Good question, I'll try that.
blrmkrl83
Iowa
The "stick" just pushes in. At least that's what my 2011 does. There's 2 different trip odometers and a timer. If it's not pushing in try pushing it kind of hard. It's possible is just sticking. Or maybe try and pull it out then push it.
02blkram47
02blkram47
Lebanon, NH
I tried this morning to push it in with quite a bit of effort..nothing happens, also tried to turn it. Not a big deal but maybe this cluster will be covered under my extended warranty..if so I'll replace it someday. Thanks for all the input.
TXPudge1868
OKC
On my '12 all I have to do is push the stick and it changes from A to B and to the trip hours too. Definitely take it in and get that looked at.
alphaprojects
