Johnn123
- Joined
- Sep 23, 2013
- Posts
- 2,090
- Reaction score
- 1,099
- Location
- Ontario
- Ram Year
- 2010
- Engine
- 5.7L Hemi
ok when i order the BDS lift i want to tell them its for a 2500 that way i can get new leafs and all. I see what your saying about the blocks i know its not the best way but for now i tow nothing and only street use so i will see about just buying the axles and all and when i get the big money for the new lift ill just do it all at once and is the limited slip better in th Dana 60 as compared to the 9.25 i have?
Personally man I would use the 1500 springs. Its gonna make your life way easier, that way you don't have to touch your frame. Very small amount of welding required to just put new perches on. Since you don't tow or anything, you'll also get better ride quality from the 1500 springs. Your truck will ride worse than a lumber wagon with 2500 rear springs. Up to you but that's what I would do.
No idea on the LSD, personally I'd just rip the axle apart and put a true locker in. I'd also regear for the bigger tires, both axles required for that.
