Savatreatabvr
Hello guys new member here, I hope you can help with my issue. Like the title says, when I do a cold start the engine clatters for a good 60 seconds then slowly goes away. When at operating temperature the oil pressure stays normal. The truck has 138k miles and runs great but I can shut it off for 15 minutes start it up and no clatter but if I shut it off for an hour or so it clatters again on start up.
I would think that would be the signs of a weak oil pump but I read that some 4.7s have a problem with oil passages in the top of the engine being blocked and not allowing oil to drip back down to the oil pan which means no oil to pump back up. So has anyone dealt with this situation before?
