Redtruck-VA
- Jun 29, 2010
- 5,864
- 984
- Location
- Virginia
- 2003 & 1989 D250 RWD
- Hemi-5.7, 5.9 12v & 24v diesel
The cats was mentioned as a big difference as the 03 has only one large one immediately in front of the muffler. Where as the 04 has two smaller cats located on the mid pipe behind the exhaust manifolds before joining at the "Y". This is why when looking at purchasing headers it usually states 04-05 models excluding the 03. The headers are the same, but the mid pipe (Y pipe) is different. Long tubes, you are fabricating your own pipe's and using the Off Road Y (ORY) is the way to go. The original 03 cat can be used or duals cats installed behind the collectors by modifying the ORY pipe. The 03 cats outflow anything out there so a pair of those really work well. The 03 has only one forward O2s and one rear O2s, where as the newer models have two forward and two rear. There is no issues associated with using only one O2s reading from one side of the engine. There is some differences with radiator reservoir tank, the 03 uses a power steering pressure switch that controls idle speed, that the newer trucks don't have. For tuning, there is no idle, rpm or speed adjustments available from DSP (CMR) tunes. SC3815/3865 can adjust the rpm and speed limits. DSP has corrupted more than one PCM causing anti-lok (ABS) sync issues when adjusting tire sizes. SCT supports 03/4.7, but not the 5.7. I believe for hard core DIY the 03 is easier to work on then the newer trucks. I'm just rambling this morning so bare with me....
