2003 trans swap
Farmer888
ontario
So haven't had any replies on my previous post about having trans issues.. Just wondering if I do swap to a used transmission, What years 545rfe will work in my 2003? is there different wiring on the newer ones? Should I just look for a 03 trans?
Thanks
Fast69Mopar
Thanks
Hey. Just saw your post and it sucks no one has responded yet. I'll see if I can provide some RFE insight. So here goes...
45RFE and 545RFE are exactly the same transmission. The only thing that makes the 545RFE a 5-speed unit is the software in the PCM/TCM. In the 45RFE 4th gear is utilized by applying the OD Clutch and the 4C Clutch. With a new software change for the 2003 RAM trucks Chrysler was able to give us a 5th gear by applying the OD Clutch and the 2C Clutch thus giving us a 0.67:1 ratio.
For the 2012 MY, Chrysler decided to start calling the RFE a 6-speed hence the 65RFE. This transmission is identical to the 45RFE and the 545RFE except for a revised torque converter.
So, when it comes to shopping for a unit there are plenty of them out there that are available. If you can snag one from a 2012-2014 Ram 1500 you will get the revised torque converter. Happy Transmission Hunting.
DomCard
Las Vegas, NV
5.7L
So the 68RFE will work in an 04 without any programing? I know 2014 have a 8 speed tans option. I am sure that one won't be plug and play.
Fast69Mopar
The 66RFE and the 68RFE is entirely different. The 65RFE is tht same trans as the 45/545 but with a different converter.
DomCard
Las Vegas, NV
5.7L
my 545RFE seems pretty good for now.. I know there's a little rough shift from 3 to 4th. So I know it's just a matter of time with 230,000 miles on it. I am first owner and always done fluid change at about 60,000 miles.. I'll have to keep an eye out for 65RFE.
03Yo2uk3
Buckeye Az
so theoretically I could get a tranny of a 2012 and put it into my 2003?
HemiLonestar
Navy Badge Coast Guard
MD
As long as it was 2wd to 2wd or 4wd to 4wd. If not then you have swap the t-case adapter and tailshaft (easily done).
