new to the forum and just getting my way around here. I'm sure this question has been asked several times before but I'm not having any luck with my search. If someone can direct me to the thread or sticky I would appreciate it.
I'm looking for some basic information and best known methods of replacing the oil pump on my 04 RAM 4x4. The Haynes manual tells me I have to raise the engine to get the pan off and was wondering if this is truly the case or is there a trick to getting this off. Like everything on this RAM lately I've started to get the oil pressure drop while idle. The level is good and oil isn't that old but I do have about 100k on this motor but 200k+ on the entire truck. I experience this about this time last year but my mechanic said that this was due to a sending unit issue and possibly the wrong synthetic blend viscosity being used at Valvoline. He changed the oil, filter and sending unit and all was good for a year. Should I "shotgun" the pump or change oil and sending unit again. These to me would be low hanging fruit and cheaper. If the motor needs to be raised to do this it's off to a new mechanic (long story).
I'm open to suggestions and welcome all input.
