Marco1
I have an issue that l was wondering if anyone else has or would know how to correct. First start of the day is no problem. If I restart within 5 minutes also no problem.when I restart 10 minutes later it will be difficult to start without pumping the gas while holding the key. It will remain difficult to start until it has sat for 8 or more hours then will start fine. Does run well while running but does idle a little slow sometimes. Will give me po302 if I hold key without feathering the gas pedal. So far I changed all spark plugs,yes all 16. Then I removed and cleaned throttle body,replaced number two coil and it still has this problem. Oh and I ran a injector cleaner through it. Any body have any thoughts on this.
