2005 Dodge Ram Hemi 5.7 valve springs or lifters?
Revelation612
South Jersey
The last couple of years my trucks been burning oil like crazy. I’ve noticed some visible blow by, a couple oil fouled plugs, an occasional hard to start followed by a puff of blue smoke, some backfiring, and the oil consumption was insane. I would have to add atleast a quart of oil or 2 a week. I also noticed the oil pressure flopping around on me, dropping a little low at idle.
I did an oil change, replaced the oil pressure sending unit, replaced the plugs, and replaced the plenum gasket (I believe it’s called) right under the intake. (I was told it could be the oil loss culprit).
It seemed to run good for a while. I noticed I was still losing oil some how but assumed it was probably valve seals which was next on the list. I’ve been just topping the oil off as needed until I had the time and money to work on the truck.
Fast forward to last Thursday, I was heading home from a job replacing a hot water heater about an hour away from my house. Im on the highway and as I’m trying to accelerate it kept backfiring worse and worse especially if I was headed on the slightest incline. My oil pressure kept dropping out on me. I couldn’t drive fast and it had no power on the highway, every time I’d try to accelerate is would sputter and misfire really bad. Thing sounds like a train coming down highway. By the time I got home after a slow drive it sounded like I completely lost a cylinder the way it was running. Oil pressure is dropped completely to zero, and the oil is a few quarts low.
I pulled the valve covers and found a few rockers with play in them. 2 of the rockers I can wiggle side to side and pull them by hand with little resistance, it’s not snug to the spring is best way I can describe it.
I also tried having someone turn the key to make sure all of the rockers are moving with the springs, and they do all move.
Would such little resistance on a rocker arm mean the springs or valve seals are bad? Or would it more likely be bad lifters?
I’m just trying to understand how the rocker has so much play between it and the valve spring I guess. I appreciate anyone’s input on the issue
jr27236
New York
Well first you need to put the engine at TDC (top dead center) and check your lifter gap and then youll rotate the engine and do it again on others. Its a very simple procedure. The first thing it sounds like you need is a service manual. But at the end of the day you may have wiped the lobes off your cam.
jws123
nj
Mileage? and have you changed your pcv valve?they go bad over time will make it burn oil also it would not hurt to do a compression test.
Revelation612
Revelation612
South Jersey
I’m sitting at around 165,000 miles. And yes I did replace the pcv valve.
I’ll make a compression test one of my next steps. I’ll try to do it tomorrow morning
Revelation612
Revelation612
South Jersey
For TDC, do I have to pull a spark plug, turn the engine slowly by hand to a certain point?
I hope the cams not damaged. I was hoping this was just a spring issue
jws123
nj
Older rams do not have cam issues only 4th gens did you scan the truck any codes? also are you sure your dipstick is correct? is it oem or look replaced if overfilled the truck will burn oil.
HemiLonestar
Navy Badge Coast Guard
MD
The hemi doesn't have a "plenum gasket". Only thing under the intake on your engine (or should be, anyway) is the insulation pad. Intake ports have o-ring gaskets around each individual port. How many miles are on this engine and has it ever been overheated?
