Hey everyone, first post here, desperate need of opinions
I want to share my story and get some advice. Thanks in advance for reading and offering your help.
Background:
I purchased a 2020 Ram 1500 Limited 3.0 V6 EcoDiesel in April 2020 — my first diesel vehicle. Previously, I had high-mileage...
So i bought this truck about 2 months back and it would randomly stall on me whenever i came to a complete stop at a red light. It wouldn't stall while I was moving only when i came to a stop. The rpm would drop real low and try and catch it self but sometimes it couldnt and would stall...
I drive a 2015 dodge ram 1500 3.0L Eco diesel, lately I’ve been having some kind of electrical issue. What’s been happening is it takes a minute for the battery to get to 14V, once I start driving after letting it run for a minute it flashes on the screen “battery low voltage” and the voltage...
Hello everyone
I recently ran into a problem yup the 4.7 exhaust manifold leak. So I was tould both exhaust manifold needs to be change. So I have been searching the internet and I can’t find a store or web site that sells the manifold for the 4.7 v8. If anyone has any suggestions please let me...
So my 2015 5.7 started ticking with a bit of a knock 2 days ago . I changed the oil and there was no metal in the oil. It looked perfect, however, It was still making the ticking noise. I had to drive it 300 miles back home, so I drove in tow/haul mode. Milage was normal, temp was normal, but...
Been having issues trying to find anything about the relay from this truck. I don't know where to look so I'm resorting to asking online. Please help!!
My stock UConnect LCD screen has mysteriously stopped working. I started the truck, saw the LCD screen start to boot up properly, but then it flickered and then went out. It’s been displaying nothing ever since.
Checked the hidden radio fuse, it’s still good. Disconnected my negative...
Afternoon I've got a 5.7hemi/545rfe chrysler aspen and I've replaced the shift solenoid with 2 new ones,one from autozone then currently now one from koi auto parts it keeps throwing the same code,you can punch the gas pedal up until 30-45 mins of driving after replacement,only a p0850 code code...
Ok so I've bought a 19 Classic with about 22k miles on it a few years ago. It was all stock except for Mopar leveling kit. It rode smooth for the first few months until I hit a piece of rebar on the highway, resulting in a flat. Then I got a replacement tire (275/60/20) and it started shaking at...
2017 ram, was out bird hunting and along the way I hit a piece of wood which punctured the transmission pan. I continued to drive not knowing I had even hit anything. The truck started having a warning on dash saying the truck 4x4 is unavailable. then there was a grinding and a bam truck slammed...
I removed my dash to get a new on in my 2000 1500 4x4 5.9 now I get no power to my cluster no horn chirp when locking and no crank no start hoping someone with a little more knowledge can help me out
Ok here it is, I have an 06 Ram 1500 and the oil pump went out, causing it to overheat and blow a head gasket. As the truck has over 300k miles on it we opted to go for a rebuild versus a repair. Since then the mad scientist and I tore it apart and we have replaced the pistons, rings, entire...
So yesterday after about two hours driving…I parked and had a brief conversation with a nephew when my 2016 Ram 2500 6.4 just died at idle! I pulled codes and got all injector codes 1-8 open circuit…I cleared codes, removed battery posts for 5 min. Reconnected post tried starting, crank no...
My grandfather passed away in January and this was his vehicle, I have it now and this is hanging under the truck the piece that broke was in the driveway is this the fuel pump? Does it just need clamped back up? Please help
So I have a 02 3rd gen 4.7 dodge 1500.
Just today I was driving floored it to get onto the highway and once my truck passed 4000rpm. Everything electronic turned off on my dash my radio everything. The engine stayed on and as soon as I let off the lights and everything came back on. There was...
I’m getting ready to order wheels and tires for my rumble bee, I’m gonna get either the 22x10 hellcat replicas or the 22x10 srt-10 replicas, I have 2” drop shackles in the rear and plan on new bilstein shocks in all four corners. I wanted to know what tire sizes to get for my wheels and not have...
Ok so I’m at the point of using my full coverage to get my money back, I bought a 09 ram 1500 4.7L 4x4 two weeks ago, was told it jumped time and had everything replaced top end. Checked it and it had three codes being thrown. P0016 p0405 and a misfire cylinder 6. I cleared the codes and misfire...
Hey fellow Ram crew. I'm looking for a 2020 Ram Built-to-serve in Patriot Blue.
I'm willing to take over a lease or buy used. Or if someone's turning in a lease, I can buy off them instead or returning the truck.
Do you know anyone looking to get out of a lease or sell theirs?
Thank you...
I recently had an oil change 5w-20 and filter changed on my 2019 Ram 1500 5.7L. When I start the truck it displays 0 psi for then jumps to around 55-60 psi within seconds. Drove around the block about a mile and a half turned off the truck and the psi drops to 0. I’m monitoring this through the...
I have a 2008 ram 1500. I was driving to work this morning and I stopped at the drive thru, while I was ordering I let off the brake and the engine seemed to rev a little but I thought nothing of it. Later on down the road about a mile I stopped at a red light and the engine completely cut out...
Check engine came on slowing down for a red light, green came on and when I accelerated the truck just sat there and literally took 15-20 seconds to go past 4 mph and this popped up. Anyone know anything? Thanks in advance. Also throws a modulator something code.
Good morning or evening depending which timezone... I'm in Georgia. I got here by googling Ram forums. I have been driving by a 2013 Laramie Longhorn (limited?) for sale for almost 3 months now...
Its a beautiful truck and I would love to be its new home.... I have been burned so many times...
