daytona701
- Feb 17, 2018
- 11
- 1
- Location
- Carriere, Mississippi
- 2012, 2007
- Hemi 5.7, Cummings 6.7
Was driving at 40 mph and engine stalled. Check engine light and etc flash light came on. Battery’s are 2 years old with 12.68 volts. Scan tool says the pcm is seeing 12.3 volts. Crankshaft position sensor was damaged by something scraping on sensor face. Couldn’t see what caused the damage to the sensor. Installed new sensor, cleaned and tightened battery cables. Gas and voltage gauges work when key is turned on but instrument lights don’t all turn on. No start. Engine doesn’t make a sound when key is turned to start. Will check grounds next. Looking for information to perform troubleshooting.Thanks for suggestions.
