2007 battery drain
2ramssofar
long island NY
I have a 2007 Ram Megacab. Had an issue with Electronic Throttle Body and them a Cam sensor. Replaced both. Now I have a battery drain issue. If vehicle sits for a little while, I come back to a dead battery. I replaced the battery just a month ago (after the issue first showed) and it seemed to be the issue, but I am back to a dead battery again. I must have a short or something draining the battery that I can't see as obvious.(yes, checked all interior, exterior lights and typical things that might cause this. Additionally, when I put a trickle charger on it, it indicates a bad battery. Could that be because the drain is more than the trickle can keep up with? Any thoughts appreciated.
rockyj69
