klackmeal
About two years ago I reached out for auto trans info. The replies were very helpful and made for a successful fix/rebuild.
Once again I reach out. This time for a simple crank with no start situation. I believe the no start is due to a fuel issue; no fuel pressure. The schrader valve on the fuel rail shows zero fuel pressure. There is no buzzing sound from the fuel pump when the ignition is turned on. I am thinking the problem is the fuel pump, relay, or wiring.
A look online shows that this is not an isolated problem. Fixing it remains elusive. My truck is a 2007 Ram 1500, 5.7, automatic. It is probably classified as a “work truck”. Per “Vertical Visions” my vehicle does not have the fuse block that has a bypass fix. What would be really helpful would be a fuel pump wiring diagram. Also, helpful: Is there way for unplugging the wire connector on top of the fuel tank without dropping the tank?
Thanks for reading. All help is appreciated. I am including a image of the fuse box.
