Hello everyone new here and looking for help. Truck has no throttle,will idle. Cranks after several seconds of turning over. Cel code 335 Crank Pos Sensor. Replaced being a 13 dollar part no change. Read that during cranking PCM reads Cam Pos Sensor. Replaced no change. Power at connector to CPS is within spec on one side and below on the other, Checked wire back to PCM and is fine. When looking at plug left side has 4.92 volts, middle good ground, right side 2.73 volt all the way back to PCM. Wondering if PCM has crapped out. Truck has 86xxx miles. Have also reset PCM three differnt ways no change. Thanks for any help.
