2010 6.7 hesitates
savoy
At highway speed no hesitation - however when starting from a dead stop, the truck will sporadically hesitate - just started this today.
I have had an EGR code for over a year - and was told if the valve is stuck all the way open, it will act like an EGR delete.
I am thinking the valve has closed somewhat and is possibly affecting acceleration.
Thoughts
danoday
Huntsville, Alabama
I know it's obvious but plugs and plug wires.
Sent from my SAMSUNG-SM-N910A using Tapatalk
S
savoy
Good point thanks.
I have been fixated on the EGR possibility - hadn't considered the plugs and wires
mtnrider
Georgia
Good point thanks.
Do you have a 6.7 Diesel as listed in your signature? If so you don't have plugs and wires.
Also if your EGR valve is stuck open it will not act like a EGR delete, actually just the opposite. It will be recirculating all the time.
If you have codes you really should get them sorted out then see where you stand.
S
savoy
Yup - 6.7.
I did check to see if I had missed something over the years - did see there aren't plugs for the truck.
I'll replace the egr - something I should hade done already.
Thank you for your comments - helpful
danoday
Huntsville, Alabama
Yup - 6.7.
My bad., I didn't catch the diesel. But I would still chase fuel air and spark to start with.
danoday
Huntsville, Alabama
Thoughts
I would assume since you have the egr codes for over year you have had the codes diagnosed?
Have you tried cleaning the valve and check for air leakage?
S
savoy
I've cleaned it a couple times. It's either the solenoid or the spring in the valve inside the EGR - they are the only 2 moving parts from what I can see.​
I will get them both checked and replace whatever is needed - probably the whole EGR​
danoday
Huntsville, Alabama
Get your codes checked it possible it could be a sensor. If the egr spring is weak it could leak air as well. Maybe clean the tube that connects to the egr also..good luck.
Agcat
