2010 Dodge Ram 1500 TIPM help Fuel pump
StephenM
Danville pa
I’m attempting to fix my TIPM. I’m having the common no power to fuel pump. I’ve done quite a bit of research and mostly all the TIPM repairs are from 2011 and up or 2008 and lower. I’ve opened up my TIPM and the layout and completely different. I was wondering if anyone had a diagram letting me know which relays or for what and which one is the FUSE PUMP
move included pics of mine mostly all the repair guides and videos are from 2011 and up which are different
red express
Pearland
I used Vertical Visions jumper cable for almost two years on my 2011 Ram 1500 . As they say the jumper is not the cure. Mine started doing the same thing with the cable. I sent it off to them and less than ten days and $225.00 got it back. Two months later no problems.
Jeepwalker
WI
2012 Reg Cab, 4x4
....or you could just replace the relay itself, since you have the TIPM already out. There's a image on Vertical Visions which shows which relay it is. When you're finished soldering it in, put a few daubs of clear nail polish (or wood varnish) over the solder joints for moisture-proofing. I bought one to throw in my truck's glove box, in case it flakes out. Inspect your TIPM, maybe it's just a cold solder joint and not the relay itself. The relays are spec'd for a million cycles, but of course cut that in half.
Submariner47
wv
hemi 6.1
thought I had clogged filter so replaced fuel pump found real issue no power to the fuel pump put in a jumper with a switch truck runs now but would like to repair correctly 1. the jumper is direct feed to the pump with a switch turn off when truck not running will this work as a temp fix. what and where is the TIPM ??? should have done more research before replacing fuel pump
Jim BB
Hamilton ,ON
2019 Ram 1500 classic Express
Looking at your pic it also shows lots of corrosion on several of the terminals may be start by trying to clean them and other ends first before messing with jumpers and resoldering it may be a lil more work but why replace or do something that is not necessary
