2010 Ram R/T Audio Install
chithead
Concord,NC
2019 Ram Laramie Black
5.7L HEMI
Well after a few different setups, I believe we've found a winner.
Morel Hybrid Ovation II 6 component set - using the passive crossovers on each front channel of the amplifier
Morel Ultimo SC 12 subwoofer - single 4-ohm voice coil bridged from the back two channels of the amp
Zapco Reference 1000.4 providing the power
Rockford Fosgate RFX-8240 (made by Denon) being the brains of it all
Going to take deadening quite a bit further, and also take what I learned with the wiring from the previous install a few steps more.
chithead
chithead
Concord,NC
5.7L HEMI
A few pictures of the Morel comps for those that are curious:
chithead
chithead
Concord,NC
5.7L HEMI
And some pics of the Ultimo SC 12"
chithead
chithead
Concord,NC
5.7L HEMI
The Zapco Reference 1000.4
chithead
chithead
Concord,NC
5.7L HEMI
Wiring is labeled, clear heatshrink over that, TechFlex, and heatshrink over that, then a ring of red heatshrink applied to the positive and black to the negative wires for even more reference, ends are "tinned" (solder applied for a stronger connection at the amp and crossovers", then the main "run" going through the cab is ziptied about every 6 inches to keep it secure.
chithead
chithead
Concord,NC
5.7L HEMI
May I introduce... the RFX-8240:
chithead
chithead
Concord,NC
5.7L HEMI
Starting on the rear wall:
Combination of tractor trailer patch tape to cover all the holes, and then FatMat:
My father-in-law has all this rubber laying around. Apparently they spread it down before spraying on foam roofs - It gave me an idea.
Relocated the ground wire:
Applied some butyl rope:
And voila:
chithead
chithead
Concord,NC
5.7L HEMI
Ok back to the crossovers, some of you may recognize this area from the CleanSweep installation previously, easy decision to mount the crossver there:
But the passenger side... well. Not as easy of a decision to make.
Maybe in the upper compartment... no won't quite fit.
Behind the lower compartment... no nothing there.
Hey wait a minute, I forgot this panel popped off:
Oh now I remember, this is where the factory Bluetooth module was mounted. A PERFECT spot!!!
chithead
chithead
Concord,NC
5.7L HEMI
But how to mount it... Oh wow, I forgot I had this old PS1 housing laying around, I wonder if...
No fricking way! It fits! So we'll just secure it here:
And mount the crossover here!
I put a rubber cap over the exposed bottom screw just to prevent any wires rubbing against it.
chithead
chithead
Concord,NC
5.7L HEMI
Finished up the wires for the Big Three Upgrade:
chithead
chithead
Concord,NC
5.7L HEMI
Our "big three" wires have been added under the hood :D
ramhunter9
P-Star Jeep Wrangler
Dammmmm SON
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
mf'ing drool damnit. seriously, I need you in STL stat!
quietpeen
2021 TRX
Hellcat
that would have been a good HOW TO Thread
chithead
chithead
Concord,NC
5.7L HEMI
Continued some of the sound deadening this morning:
Also had some goodies arrive last night. I went ahead and started swapping parts over from the old carrier plate to the new. Just a few more things I need to address before putting the new pieces in the door. Went ahead and applied some deadener where I remember being trouble spots. Will add more once it's all together if needed.
chithead
chithead
Concord,NC
5.7L HEMI
Thought I'd show everyone how I got the new speaker wires into the front door. First, you have to remove the plug. Quite easy, just pinch the top and bottom on the front and back of the plug going into the door. It will then pop out, and you can unplug the harness. This reveals a very nice sized opening to run your wires through:
But... to make it MUCH easier. I removed the plug from the door. Not difficult at all, you have to remove two screws on the door side though. They are located here:
Not an easy gap to get a screwdriver into, is it? Out come the vise grips and the screwhead!
Ok now that's out of the way, pop this piece off:
And run the wire straight through. Then reattach:
And we have new speaker wires:
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
drool
quietpeen
2021 TRX
Hellcat
very nice work
chithead
chithead
Concord,NC
5.7L HEMI
Got the rest of the radio pieces in tonight:
Reticle918
