2011 Ram Stolen attempting to Repair
BigBlockDaddy
Edmonton Alberta Canada
Cummins
Hi guys, new to the forum.
I've got a 2011 3500 Ram 4x4 with the 6.7-liter diesel engine.
To make a long painful story short, my ex-gf got into an accident with my truck a few years back and things being the way they were, I ended up putting the truck into storage until I could get around to doing the repairs necessary to get my truck back on the road.
We'll, during it's time in storage, some people thought they would remove much of what was left intact on my truck. Many body parts, my big wheels and tires, most of the front end, including the hood and some of the engine.. Oh, and they also took out a lot of the interior, much of the dash, including the gauge cluster, ignition switch and so on.
So I show up, keys in hand, see the state of the truck and just end up turning around and go back home.
Last summer, I located all the engine parts required at a local wrecker and put the entire thing back together. I also took the key switch out of another truck with hopes my key would still start my truck. No such luck..
My question is, can I take my original key to the dealer and have the replacement key switch reprogrammed for my key? Does a cluster need to be in there for the truck to start? Does it need to be reprogrammed to my original key?
I need to know what I need to start the truck so I can get it into the body shop for repairs. Thanks for the help.
Brandon-w
Yukon
2015 Ram 1500
I think ur rf hub needs to be programmed to the ignition module. I can't say for sure. If in doubt maybe go back to the truck u took the igniton from and get the key from it as well as the hub Then it may work.
Also welcome to the forum
Sent from my SM-A530W using Tapatalk
the ignition switch module may need to be updated. If you had to install a new ECM that will have to need the VIN updated or the truck may start but won't run.
BigBlockDaddy
BigBlockDaddy
Cummins
I agree!... I didn't let her drive it by the way, she just borrowed it without asking while I was out of town. Didn't think I had to lock up my keys..
Kmiko
